minde28383
- Joined
- Apr 2, 2010
- Messages
- 698
PeeHell said:If my controller has the variable regen wires (red, brown, black), does it mean that the switch brakes (72v on the purple high brake wire) won't work without a second throttle ? Do I have to press the ebrake lever and the turn the second throttle ?
Could I permanently connect the red and brown wire of the variable regen to mimic a full throttle on the regen or it needs to read 5v only once the ebrake levers are pressed ?
A lot of question for something so simple...
no, you don't need to use a second throttle. Just use you high brake wire 12v / 72v purple one. I guess that's the answer you was looking for
"connect the red and brown wire of the variable regen to mimic a full throttle"
Never heard to do so. Just use high brake wire.
