I do have some limited space for my battery - but know that I will need to run high current (as suggested) and am shooting for 100A min. Interesting that you devised 131 with the math.
That was just a randomly chosen high wattage--you may need much more power than that, or less, we can't know what you'll need with the tiny amount of information provided so far.
(sorry if the below sounds "insistent" but it really does take more info than you've given to choose stuff to "suggest the best (not to big or heavy) controller to bring my
72V system alive with amazing climbing power and torque".)
So you must determine the actual power required for the job you need the system to do, under the conditions you need it to do them under, before you can choose your controller, motor, etc.
Then you must get or build a battery that can supply that power.
If you don't figure out the power you need first, then you're just as likely to be spending money again buying new parts as happening to get the right solution the first time.
Since we don't know how much power you need, we can't suggest specific controllers.
If I have to guess what you need, you probably need in the 5-digit-kW range of power, continuously, for offroad hill climbing torque as you describe. We'll start guessing at say, 10kw (you might need more), so at 72v that means you need at least 139A battery current. You probably need more than that, because at low speeds and high loads the hub drive is going to need more power as it will be wasting a lot of it as heat instead of moving the bike, so you could need a couple hundred amps from the battery sometimes, at a guess.
Everything is speculation right now, without specific information from you otherwise.
I have tried a Sabvotan 100A controller - but it is quite large, heavy and it seems a bit overkill on the amount and type of connection wires / connectors it comes with.. I know they make higher Current controllers and thought about that. The one I have barely fits in my frame!
Do you know how much current you need to do what you want? Is it less than 100A battery current? If it's more, you need a bigger controller (it might not have to be physically larger, but it would have to handle the higher current and power).
Since this is definitely a hub drive system - I understand the need to depend on the battery first and make sure the controller can support it
No, you need to determine the power required first, then get a motor and controller that can supply that, *then* get a battery that can supply more than that (because it will take more battery power to create the motor power required due to inefficiencies).
. At this point - I am just looking for some suggestions on what alternative controllers might work well on this project.
There is not enough information here yet to tell you that.
I am looking for a small and discrete basic display that I can integrate on the handlebars. Any suggestions? I have been using the Cycle Analyst for years - but want something smaller and simpler.
Well, the CA isn't a display in that sense, so if you want the functions it provides other than battery information and speedo, you'll still need it, whether you use it where you can see it or not.
For a display that's just battery info and speedo, you can get those separately pretty small.
If you need them together, or need them to integrate with the controller, such as to access it's settings, etc., or receive information from it and display it, you must first choose the controller, then find out which displays (if any) that it is compatible with, and get one of those, because displays and controllers are not generally intercompatible.
So you have to decide what you need the display to do for you. If you need it to do something that none of the displays available for a particular controller can do, you have to choose a different controller that does do those things with the displays that are compatible with it.
If it sounds like this is all complicated...well, since very little is standardized about all this stuff, then yes, it is overly complex to figure out. :/
FWIW, things like displays, and any functions you need the controller to have (like user programmability, or regen (and how do you need that to work--variable, or just on/off?), FOC (or if not, sinewave or trap), size limits, budget, connector types you prefer or don't want, etc., will all also limit your controller choices.
So unless you define those things, too, it's tough to suggest specific controllers to do them.
If the only thing that matters is that it can drive the motor with enough power for the conditions you need it to do so under, and you will work around all the other limitations, then we just need to know your power requirements, and then list some controllers that will do that, then you can decide from among those that best fit your other requirements.
