Hi - I have a 2016 Currie IZIP E3 Peak. I just had the battery refurbished and it was working well. After two weeks with the new battery, I used pedal power with a little throttle assist to get up a small hill and heard something snap/break. The motor stopped engaging the gears/clutch. The bike works with no power assist, but I would like to use the new battery and motor. In the air on a stand, the motor whirs and throttle works. On the ground, there is no power assist and it makes a rough noise sometimes - like gears that aren't engaging but hitting each other inside the Transx motor mid-drive hub.
I love this bike so much and would like to repair it or replace the motor. I have no motor experience, so where can I get this repaired or purchase a replacement motor and have it installed?
Thanks in advance for any help you can give.
