Bengy22
- Joined
- Dec 31, 2019
- Messages
- 199
OK, so I did another speed run today. The ambient is around 83°F. At about 6.8km this time I experienced thermal throttling. Check temps on the stator showing 70.8°C (top speed was about 65km/h, the wind speed seemed negigible although I suspect it was slightly at my back)
My turn around time was about 5 minutes. Temps had dropped to 68.8°C. Not wanting to be bouncing off the thermal limit the entire way back I set my speed to 40km/h. I did a couple km's at 40km/h and noted the temps was dropping about 4°C/km.
I increased to 50km/h and the temperature seemed steady. It had cooled down to about 49°C and stayed around 50°C while maintaining 50km/h.
Cooling is all about the ambient temp and I have to say 40°C is hot. 28°C is relatively temperate. Perhaps even more importantly is the temperature of the road, I have to think being 12" from the asphalt the actual cooling air is well above ambient. Either way a 12°C difference is going to be noticeable.
By "hot" I'd say after 1 second your brain goes in to reflex mode and you pull away. (I really need to dig out my digital thermometer, this is very unscientific)
Off hand I's say you're reading is on the high side. In my experience at 40-50km/h the motor goes to about 25°C above ambient and stays there. If you have a head wind that's going to change a lot. At 60km/h the temperature rises to about 30°C above ambient pretty quick, then continues to rise about 2°C every km. At 65km/h that increases to about 4 or 5°C every km. Rough guess.
It's not going up to 40°C here anytime soon so you're going to have to do some mathematical gymnastics to see if your observations fit or not.
Thank you for the huge amount of detailed information! Yes haha I agree 40°C is definitely hot, I've only ridden the ebike twice in the morning in 2 months because of it haha. Maybe so, it's not completely horrible until you hit a red light and then you really start to feel it.
That's probably what I would expect with the hand temp. Well the problem with my data at least is I'm trying to compare my external temps when I ran a shunt mod to the internal sensor with a ludi v2. I have noticed a huge discrepancy from exterior to interior though. I have mine to throttle at 90°C (luna sets it to 100°C but I set it lower) and I did a .5 mile hill climb and at the top I was throttling at 90°C but exterior was only 43°C. Makes me interested in what the internal temp would be when I would take it to 60°C external.... But I ran that shunt mod for 2500 miles and when I opened it the copper it looked brand new so 60°C exterior seems like a good temp to stay below. It also doesn't help that bafang has used two different sensors and put them in different locations during the bbshd production, so maybe ours are different which I'm sure also wouldn't help. When temps outside cool down I probably will experiment with raising the temp limit and checking external temps to compare my internal vs 60°C external. It was a harder to bring the motor to throttling when it was around your temps though, right now feels like I can do it in a blink of an eye haha.
For what it's worth mine also cools down a lot faster than yours, usually when I'm close to throttling temps I back off to around 25km/h'ish with PAS around 200w, and I would say within a minute I go from 90°C to 55°C. Makes me think maybe my sensor is placed very close if not on the coils where yours is more far away. Resulting in mine peaking a lot but yours giving a more steady reading? Idk but interesting to hear about your experience with temps vs mine, very hard to find people talking about interior temps on the bbshd!
