JgossofArk
New here
Good day!
As the the title reads, I am trying to revive a nonop ebike.
1st off batteries have voltage and I have checked that it is getting to the controllers.
Does a diagram exist for the controllers on the Ariel Grizzly?
I do not have any power of any type coming out of the controllers- keep in mind this is testing with no display but testing wires that run into the display and all other wires I could access.
There is one lead that comes out of the main controller that is short and has a red connector- would a controller have a switch on it to allow power, I am afraid to jump that connector as I do not know but seemed like the only logical option as again, no power is going through the controller.
All that being said- when i tried to open the controller it was jammed with silicone- are these serviceable- if not can anyone recommend a replacement?
The best guess I have found this far is here.. Best guess
The motor cables going to the controller have the 3 main pins and then 6 tiny wires in them.
Thank you!
Thank you!
