DaDo.Bzz
⚡ Regular
- Joined
- Feb 12, 2015
- Messages
- 251
Hello bafang ebikers
Introducing speed unlocker, configuration tool, calibration and also simple firmware fupdate - K1 Flash
Would you like to set or tune motor controller parameters? K1 Flash is compatible with all Bafang CAN bus motors (5 pin connector with "house" shape). Simply edit AutoSet.txt file on included SD card with your favourite settings.
Also can download motor firmware for M500, M510, M560, M600, M620 and M820 motors and run Calibration.
Simple as 1, 2 ,3 ...
1. Insert included SD card (with set of firmwares - over 120 firmwares)
2. Power up K1 Flash (over USB-C cable from your mobile, power bank, charger ...)
3. Connect to your CAN motor - steady green LED light means all set and you can unplug device
In a minute your motor is flashed and parameters set according text file (editable) on SD card.
More info, pictures, video and ordering info at web page:
www.k1ebikes.com
A quick video
You get a collection of bin files on SD card (over 120 bin files). Or simply add your firmware file into SD/ForceFlash directory and device will load it once compatible with your motor.
Tested on M500, M600 rev.A and B, M510 FC1.0 and FC2.x, M560, M620, M820 , M400, M300, M420, and many Hub motors.
Speed unlock, Circumference and Wheel size supported by all Bafang CAN motors, including CAN hub motors.
If you want only speed unlock and set power parameters (supported by all CAN Bafang motors including CAN HUB motors) get a K1 Flash Light - starting at 110 Eur. If you interested please contact me at info@K1eBikes.com
