tylerwatts
⚡ Regular
- Joined
- Sep 14, 2012
- Messages
- 212
Modified original sketch as a guide, adapt to suit your motor/swingarm. Remember if you recess the nuts, make it big enough for a socket to turn the nut, mustn't be tightened a lot as bjork said, just hold axle in lace before tightening the end caps.tylerwatts said:Hi bjork
I understand your concept, similar to motorcycle front axles. I'll try sketch it.
Cheers
Tyler
Bore for axle and flats should be as wide as practical and slightly interference fit so the cap firmly clamps and locks the axle in place.
Cheers
Tyler
