I might be able to help. I offer value for money, not cheap. I'm currently booked out for the next few months at least. Check my website in my signature block for info.
Cheers
Hey CD, checked out your website, I knew you were offering builds/services, didn't know you had a website identifying it. Pretty cool man!
Wondering if anyone has installed surron forks on their stealth bomber. I ordered the standard surron head set bearing set to see if it will fit. Can't find any info on dimensions online yet.
UPDATE:
Ended up using the standard bearing and bearing cup for the lower bearing and the bicycle bearings I had for the upper one. The steering tub is too short to use both the tapered bearings on the surron kit. Forks feel very nice on the rocky stuff, very happy with the upgrade.20240709_193934.jpg
It's been over 2 months since the rebuild, and even though the good riding season was over, I've still been able to log enough miles to get a real good feel for how well it works now. I've been saying it was great all along, but often after familiarity sets in opinions can change. That's not the case this time though, if anything I like it more now. It also doesn't hurt that the SurRon seat I installed a few weeks ago is probably the most comfortable seat I've had on any bike I've owned, including my Road King. This build was greatly aided by the fact that Allex, and bigbore had already blazed a trail through the jungle that was easy follow. Because of Allex I knew ahead of time that a Kelly KLS7218S controller would work well, and bigbore proved that a QS205 motor would fit my swingarm. What I wasn't totally prepared for was finding out just how well those parts actually work together in my bike. For the record a 7218S controller is 80 amp, the QS205 is 5000w, and my battery has a 100 amp bms.
After 3 weeks of freezing ass cold, the last 2 days got up to 70 degrees, and I took advntage of it both days. I just got back from a 40 mile ride around town. I really enjoy the extra power I have in traffic now, especially above 45 mph and in the 45 to 55 mph range. Before, that was full throttle, high power consumption territory, but now I can cruise at 50 mph on partial throttle, and not much voltage sag. At heavy acceleration there is big voltage sag, even more than before, but cruising at any steady speed it seems like the efficiency is noticeably better than stock with very little sag. Even though I find myself cruising around at higher speeds now than before, my range hasn't dropped much. Todays ride only used a little more than half my battery. It's like the best of both worlds. One last thing I'd like to mention is that even though I no longer have a amp hour meter, I really haven't missed it at all. I can tell all need to know about my battery by the voltage alone.
Questions.....
What motor were you running before you installed the QS205?
Is the performance increase a result of multiple changes? Just wondering how the two motors compared...if that is even possible considering there may have been changes besides the motor.
Thank You...nice looking bike wiht a great set up.
Questions.....
I think the answer is yes. Before the QS I was running a stock 5403 Crystalyte motor, and stock 65 amp square wave controller. Now it's 80 amp Sinusoidal Kelly controller, and QS 205 5000w. The battery is the same 72v 35ah. There was about 10 years of technology separating the old from the new.Electronaut 2024.jpg
I think the answer is yes. Before the QS I was running a stock 5403 Crystalyte motor, and stock 65 amp square wave controller. Now it's 80 amp Sinusoidal Kelly controller, and QS 205 5000w. The battery is the same 72v 35ah. There was about 10 years of technology separating the old from the new.View attachment 355738
And the tassels are 80 year old technology, a perfect blend!:D
Hello again,
I am still on my quest for a stealth electric bike, can I get some advice on this bike? It looks well used, he wants $2000AUD but states it needs a new battery. The motor looks like it may have been replaced?
The stickers say P7, but i think it is a fighter P37?
441950555_2485794271604373_6673968872175127715_n.jpg450474561_873387774607377_585982516906262090_n.jpg450479208_943640917536407_5799371308189935772_n.jpg450909848_406162041830136_432929425261178569_n.jpg
Picking this up this weekend for a ridiculously low price, less than a set of forks lol. I already have a new in box risunmotor 80a controller kit that's been waiting for a project that I plan to use. Can someone give me the original controller specs, also I'm looking for some side panels & a Garmata seat.
Yes it's a Fighter. That price is ok if everything works.
If you get it, I can build you a battery, just PM me.
Cheers
CD, I have a couple of questions, At first I thought it was late 2012 early 2013 Fighter as they CA cutout on the frame was enlarged in late 2013 for the DC1 and the H3540 motor was phased out and the H40xx motor was implemented at the beginning of 2014. But on the frame and seat triangle, it list P7 which came out officially 2 years later in 2016 if I recall. But the high speed Schlumpf clone speed drive was and is what the Fighter comes with. If that is indeed a fighter with P7 markings the serial number would have to be between 100 and 180.
Pretty sure it's a Fighter....in fact it looks like it could be Quite Rush's old unit....if you go back far enough in this thread you should find some of his old posts if you want to confirm.
Cheers
  • Like
Reactions: Rix
Cheers
Yes, thought it could be Quiet Rush's bike too. The only thing I am certain on is its pre 2014 as the frame cut out is for the CA and not the DC1.
I've had my Bomber now for 11 years, can you believe it? The whole eBike world has changed drastically since I bought it. I've gone from seeing 1 eBike a year, to seeing at least 4 everyday. I've kind of changed to. I was 59 when I bought it, and now, oh lordy I'm 70. I still ride everyday though. I go on a lot of group rides, and even after all these years people still think my bike is brand new. The worst thing I can say about my bike is, it's a little too nice. When it rides up, sometimes it's like a pretty young girl just walked into a room full of ugly beachie's. Surprisingly it gets the most respect from clone riders. They're usually the only riders that actually know what it is. The reason I bought this bike in the first place was for commuting, and I still commute 30 miles round trip across town once a week. That's what it's really best at, going fast in traffic. For at least the last 3 or 4 years I've been looking for a new bike that I could use mainly just for joyriding and cruising, but to no avail. I haven't seen a single new bike that floats my boat out of hundreds I've looked at online. Until last Wednesday. It's supposed to arrive tomorrow, and when you see it you're going to flip you gourd.
Alright, gird your loins. It's my Bigniu BGX. Wait till they get a load of this thing at Strokers.
  • Like
Reactions: Rix
I hear you on everything. I remember when I got my Bomber in March 2012 (I think it was March) rode that thing every day snow or shine. I want to get back to that. I got a couple of more years before I retire. 2 years one month actually. Going to get back to riding daily or almost daily. BTW, your E chopper will be a hit at Strokers.
I just finished building my first battery pack for my Bomber. I tried to find an adequate replacement for over a year for my third worn out battery, but no one wanted to build one like I wanted, and Stealth aftermarket is nonexistent. Now after building it I can understand why, it's a tough one to make, but it's worth the trouble. Now I don't have to rely on anyone for a new battery. Since installing the 80 amp controller, and QS motor the year before last, this is the first time my bike has been able to really take full advantage of it. After all these years my bike has never run this good.Electronaut 11 2024.jpg
I just finished building my first battery pack for my Bomber. I tried to find an adequate replacement for over a year for my third worn out battery, but no one wanted to build one like I wanted, and Stealth aftermarket is nonexistent. Now after building it I can understand why, it's a tough one to make, but it's worth the trouble. Now I don't have to rely on anyone for a new battery. Since installing the 80 amp controller, and QS motor the year before last, this is the first time my bike has been able to really take full advantage of it. After all these years my bike has never run this good.View attachment 359698
Glad to hear it TV, Got any pics of the batter build in progress? That's the one area I lack skillz?
I was able to use plastic cell holders, which cut down on a lot of extra work.
The copper composite strips were a revelation. Without them it would have been almost impossible to build a good battery that can handle this much current with only 7p.
In order to get it to fit I had to build the battery in 2 equal halves that fit sideways in the frame. My good friend who happens the a double e helped me join the two halves together. He's really good at soldering. His idea to connect the two sides together was a lot better than what I was planning to do.
I saved about a $1000 making it myself, and next time it will cost less, because I won't have to buy all the tools again.
I used Samsung 21700 50S cells recommended by Alex.
I bought my last battery on Aliexpress but it's is no longer in production. It was the same 35ah, 72v as my new one, but the big difference is this one can support 175 amps. The Chinese one was only good for 100 amp. This one has a lot less sag, and I expect it to last longer. The biggest limitation I ran into was the biggest BMS I could find that will fit is only 100 amp. I would have gone 120 amp if I could have, but I don't need it. My Kelly controller is only 80 amp, but I'm pretty happy with it. It was also suggested by Alex.
Hi all. Just got word yesterday my F-37 is finished and will be sent soon/today.
Brand new straight from Stealth so no DIY.
However a few years ago I built some electric skateboards. Built the batteries, programmed the controllers etc
So, interested in ebikes now. It will take a while to become familiar with the motor/controller hardware.
I think there's 17000 comments in this thread.
Bit of homework to do
