Hi,
I have been planning my first e-bike build for months, and I think I am ready to start purchasing all the components I need. Below, I will briefly summarize my plans and would be happy to hear your thoughts and critiques.
The goal is to build a hardtail city/commuter bike with an average maximum speed of 30-40 km/h, which can also be powerful and fun to ride. For my daily needs, I expect around 400-600W of consumption before the next charging.
1. **Motor**: Grin All-Axle Standard Wind
I chose the standard winding because it is 1-2 percent more efficient due to its slightly higher copper fill.
The disadvantages are the need for higher voltage, which requires a controller with high-voltage MOSFETs that have higher power losses. Also, this comes with potentially dangerous voltage levels and fewer compatible components like BMSs and chargers.
2. **Controller**: Tronic X12 30s (VESC)
I like the VESC a lot. It is highly customizable and appears to be a well-polished project. My concern is that the settings for a hub motor may not be plug-and-play. Some people have reported problems, especially with cogging at higher speeds. I'm hoping for the best!
Choosing Tronic wasn't difficult; there are very few high-voltage VESCs. It has a very small form factor, seems to use high-quality electronic components, and while there aren't many reviews, the ones I have found are positive.
3. **Battery**: DIY Pack Made from Molicel P45B in 27s3p configuration.
I'll use a copper-nickel sandwich construction for the battery. I chose 27s3p because I need high voltage for that motor winding and have space for around 80 cells.
For a 27s configuration, my peak battery current will be 60-90A, with a maximum duration of up to a minute before risking temperature damage to the motor.
For everyday use, the battery current will be only ~10A (3.3A per cell).
Theoretically, for such currents, the Samsung 50S might be a better choice. However, I’m not entirely convinced that the slightly better capacity at low currents is worth it. The P45B has a better internal resistance, seems to run much cooler and is better known for quality then 50S.
4. **BMS**: Ennoid XLITE-V4 32S
Possibly the only BMS that can truly communicate with the VESC via CAN bus. I didn't find any alternatives.
5. **Charger**: Still searching
My requirements:
- Variable voltage and current with fast switching between different profiles.
- Manual selection is also acceptable (e.g., using knobs), but it should be convenient, not using a potentiometer requiring a screwdriver.
- It is important that the charger is quiet. Ideally, it should be silent during slow charging (1-2A) and have a fan, that to turn on only when needed for fast charging.
My idea is to make a removable case that will accommodate both the battery and the controller and will slide into the bike’s triangle. It will be made from acrylic sheets and 3D-printed parts. The top will feature a 300x80mm heatsink, to which the controller and the battery BMS will be attached.
The phase wires will be equipped with bullet connectors, and all other communication will be managed through a D-sub 25 pin connector. The bullet connectors and the D-sub will be combined in a custom 3D-printed connector for quick connection and disconnection.
The charging port will use an XT30 connector.
ebikes.ca
My requirements:
Motor Simulator - Web Tools - Resources
Our ebike motor simulator allows you to easily simulate the different performance characteristics of different ebike setups - with a wide selection of hub motors modeled, and the ability to add custom batteries and controllers and set a wide variety of vehicle parameters you'll be able to see...
