hotsquirrel
My Tongsheng 500W 48V is mounted on a trekking bike with Rohloff 14 gear. No OSF installed, but heat management from ebikestuff.eu is mounted inclusive thermal sensor LM35. I am running the motor at 8 Amperes max. and speed limit at 25km/h. A second bearing on the left side of the crank is also installed. Actually I run this setup for about 4 months and 1.600km.
Since 1.500km the problems began: Especially, when I cross some bumps in the street, suddenly there is a compete loss of traction power while the motor speeds up to its idle speed. This failure is not associated with my power of pedaling and cannot provoked by increased force.
I have found two ways as a work around until I will get rid of the real cause for the failure:
1.) I can stop pedaling for a very short time. Immediately the motor will return to an adequate rotation speed and the traction force will be back again.
2.) I have installed a small push button at my handle bar, by which I can stop the motor in cases, when I have forgotten to downshift in time and cannot do it under heavy load. If the failure occurs, I simply need to use this button for a very short stop of the motor and immediately the TSDZ2 will return to ist normal function.
There is no special noise from the gear or other mechanical components, when this failure occurs. I did compare my observations with some YouTube video, where they are reporting about a failure in the sprag clutch. But they all report about a noise as if the chain would jump over the chain wheel, similar to a chain suck. I do not have such a noise.
I would be happy, if someone here could give me a hint, how or where to find the cause for this failure!
