More info here and the quote below is from this article as well:
Leafbike 1500W hubmotor, the mid-sized hot rod.
"Since the faster Kv motors (lower turn-count) use fatter wire, they have less resistance, even if you only use half of their higher speed potential. Listed below are the turn-counts available from Leafbike. I recommend the 4-Turn, even if you don’t actually travel at that high of a top-speed. The top road-speeds listed below are for a 26-inch wheel and a 2-inch tire.
4T / 13.1 Kv = 631rpm @ 48V = 39mph
5T /10.1 Kv = 485rpm @ 48V = 30mph
6T / 7.0 Kv = 336rpm @ 48V = 21mph"
The author, Ron/spinningmagnets, usually has his facts correct so I'd tend to use the Kv values he published.
