Blacksheep Engineering
🔌 New-ish
Here is my project for the winter:
Motivation and solution:
I ride really gnarly single track trails here in southern Idaho and Utah. The instant power delivery from electric is so much better than gas in my opinion but, due to other drawbacks, I'm currently on a Beta 300rr Race Edition 2 stroke gas bike and loving it. The biggest reason is obviously range. I can put 40 miles of super hard terrain on that bike and have more than half a tank left at the end of the day. Another big reason is suspension. I've tried Surron light bees, ultra bees, x260s, and even other custom builds and all of them have been seriously lacking in these areas and not good on power either, before thousands in upgrades. So my solution is to build a full size bike with the suspension and comfort I love, more than enough power thats tunable to my liking, and enough battery to go on the longer trails I like. Another goal, since the Stark Varg is supposedly the best on the market, is to be lighter and also have more range since both of those aspects are disappointing for that bike. Based on where Im at so far, thats looking very promising.
Frame and suspension components:
-I bought a 2008 KX250F as a starting point. I chose this bike because its one of the only bikes that has the honda style split aluminum frame AND KYB "SSS" forks. SSS is the Yamaha term but same deal. KYBs before 06 were not good from my understanding.
-The SSS forks are the only forks I love every time I ride with them. I have not had good experiences with the older KYBs, Showas, ZF, or WP options.
-The reason for the frame choice was to give me a lot of room in the frame without a lot of weight. Also Im an industrial designer so I have some cool visual ideas that work with that exterior frame tube shape.
Motor and controller:
-The motor I have is a QS138 70H V3 that has been upgraded by Electro and Co. They machine the gear housing from billet aluminum and do some other upgrades to help the power capability and longevity. This is currently the limiting factor as far as power goes in the system with a 35kw capability.
-The controller is the only part I don't have yet. That's because the one I want isn't quite released yet. Its also from Electro & Co. Its the Trumoto Zapper controller. Its capable of 50kw (nominal) at 76V. 600 amps max current. They said it should be released well before spring so Im still planning on using that for now.
-Other options I'm considering for the controller, if that isn't released in time, are the EBMX X-9000 and the EM-260. The x-9000 would allow me to use a 22s config instead of 21, but still results in less KW capabilities (the motor would still be the limiting factor so NBD) Its also about $300 more than the Zapper. The EM-260 would limit me to 28kw and doesnt have an easy to use programming app so that one would be my last choice, though the cheapest.
Battery:
This is a big part of the build. Im building my own battery using Samsung 50S 21700 cells (25 amp output continuous/45 peak)
-The configuration is 21s 18p resulting in 378 total cells (big boy) Based on the weight numbers on the website where I got them (18650 battery store) its about 58lbs in cells.
-Total amp output ability for the cells in this configuration would be 450 amps continuous and 810 amps peak. Sadly I have not had good luck finding direction on how to make connections that are able to take that kind of amperage so I will be doing some testing and posting it here. The max current the motor can handle is 461 so as long as I can get it to take that without any issues it will be a success.
Comparison to Varg:
Weight: Estimated 235lbs - Varg: 242lbs
Energy storage: 7kwh - Varg: 6kwh
Battery:
Comparison to Varg:
