Chalo
Super legend
Dropouts are technically bicycle rear frame ends that allow you to remove the rear wheel without first removing the chain (so, those with forward- or downward-opening slots). In common usage, the term refers also to other shapes of frame ends and to front fork tips as well. It doesn't refer to torque arms.
Most of the many e-bikes I have built over the years are front motor conversions. I think there are many advantages, but there are also limitations and I wouldn't use one with a suspension fork, or for conversions over 1000W in most cases.
Among the advantages of front hub motors:
- Pedal drive is completely independent of motor drive, and completely redundant
- The hub motor wheel (weaker) goes in the position that has lower structural demands
- It helps offset the strong rear weight bias of bikes generally, and of e-bikes specifically.
- It prevents pedaling force on the chain from damaging the side cover of the hub motor
- When pedaled, it gives two-wheel drive which helps with some soft surfaces and with climbing up onto steps and level changes
- It is the simplest and most expedient type of DIY conversion
Anyway, there's no reason to second guess your choice of motor layout. As long as you protect the fork tips with torque arms, and as long as the fork itself is up to the task, you should have no insurmountable issues with it.
