What do you think I need to do next to get the throttle working? Lets just focus on that until we get that resolved and not worry about anything else until then.
+1
Since Sabvoton's concept of "ignition" wire is different. You will most likely remove the YELLOW key switch wire from the battery+ terminal. And use it and the throttle's BLUE wire putting the key switch
in series with the wire you're going to cut and splice into.
The YELLOW wire will go on the "HOT" side, and the BLUE will go on the "SWITCHED" side. (Energized only with the key switch on.)
Recommended requirements for the wire eventually being spliced into...
1) Supplies full battery+ voltage when battery on. (So digital voltage meter is taken advantage of.)
2) Draws less than 2 amps total with system on and running. (Typical throttle cable wiring maximum current capacity.)
3) Disables everything when disconnected during testing. (Dead as a doornail would be the best.)
4) In an easy and convenient place.
I agree not to cutting wires at random. After you find a wire that has full battery voltage with the battery on. And it has a connector in line with it. Perhaps remove that
single wiring pin from the connector, disconnecting that wire to see if it disables the controller and hopefully the display also
first. Or if advantageous, jumper all the other wires in connector, and leave the one being tested disconnected.
I like your suggestion of the ORANGE wire going to the alarm system. I'd look for connection as close to the controller as possible for testing. Or possibly any other ORANGE wire easy to get to and test..
I'm confused as to the statement that all alarm wires go directly to controller. Then show a connector which seem to fit the alarm wiring colors...? ORANGE, BLUE, and BROWN but going nowhere...?
Looked at your previous earlier pictures... perhaps directly, with connectors...?
Now I realize that E-HP is pressing to put the key switch in series with the BLUE wire going to the display. Unless I'm miss understanding that.
But this would seem difficult to get to. And if you do go to that trouble, and the last choice, wouldn't it be better to switch the #1 pin or RED wire supply voltage to the display? (With the key switch off, display could not be energized.)
