I have read so many instructions that I'm little bit confused. But now I think it's clear.
I flashed two files to controller and VLCD5 display opens. Motor is on the table. I turn the crank but I do not feel response.
I will continue.
One of the test I make ont the table is the following:
- in the configurator, I select the assist mode cadence as the mode activated at power up.
- I flash the configuration.
- I turn manually the axis with the pedal.
- the motor starts running.
- if I hold the axis with the pedal, the motor stops.
Note: when I test on the table the speed sensor is not connected. The result is that the motor stop running after about 10 sec.
This is a security in the firmware (like in OSF TSDZ2). You have to power off to try again.
If the speed sensor is connected and provides a regular signal, then motor should not stop.
I also tested with the throttle. To use it, it must be activated in the configurator (there are several options in several fields).
