Best programmable controller for beginner?
Sweden
Hi,
I am just about to finish my ebike build with a Bafang rear hub motor 48v 500w bought from VARSTROM. The controller I got with the motor is a unbranded chinese controller which probably will work, but not fully programmable.
I want the possibility to control:
  • PAS-levels, both max speed and current
  • PAS-behaviour (current, slow-start etc)
  • Throttle voltage
The controller need to be compatible with P860ML (UART) display, and standard Bafang rear hub motor connector.
What options do I have?
Thank you!
Generally displays are only compatible with controllers of the same manufacturer, so you need to provide details about your current controller. A pic of the label and links would help.if it’s a cheap no name controller, then the chances they even make a programmable unit is very low. Too bad you’re stuck with using that display.
Ok, and if I don't limit myself with that display? Lishui or KT-controller?
I don't really understand the OSFW-thing about Lishui. Is the original firmware possible to access or am I needed to flash a third-party firmware that allows me to configure by my own?
Or is it possible to get another display which is compatible with my controller and have more settings?
If you have a Bafang system already, you can use the well known Bafang tool. It works with Bafang controllers for rear hub motors also.
Off topic. I need some assistance on this. I've never figured out what a Bafang controller is. I see on their homepage the variety of controllers with model numbers that start with "CR" and a few distributors that sell them (doesn't look like you can purchase directly). A lot of "Bafang" kits, call their controllers Bafang, but the controllers appear to be manufactured by Sing Yiu. Sing Yiu also seems to carry Bafang mid drive controller replacements. Are Sing Yiu and Bafang the same when it comes to the electronics for Bafang motors? I've been looking at this on and off, so I can add some links to my FAQ. Thanks ahead of time for the info.
In addition to the replies above, you can also keep your controller and display exactly as they are, and install the Cycle Analyst v3.x from ebikes.ca between your throttle and PAS sensors and the controller throttle input, and the CA's shunt between your battery and controller. The CA will then monitor battery current, cadence, and throttle, and use the limits you put into it's settings to send a throttle signal to the controller to operate the bike the way you want.
The CA itself can be moutned anywhere; it doesn't ahve to be visible unless you want to see it's info whil eyou ride. You can install a remote button (available on the ebikes.ca site) to switch between presets or to change level of a parameter. Your display still connects to your controller and does whatever it's always done.
Then you set your controller's settings to provide maximum output in all cases that it can, and the CA will then be setup by you to do the limiting.
The best part about the CA vs the typical non-torque-sensing controller is that the PAS is not simply full on for the chosen assist level, it is proportional to the speed of the pedalling. So just like I do on the SB Cruiser trike, you can use it to monitor a simple cadence type PAS sensor and fully control the bike with just that. You can use a torque sensor if you want to, but it's not necessary.
If you look around at Stancecoke's posts, you'll also see links to Lishui controllers and user-installable firmware that lets you do this without the CA.
I don't know if the VESC can do it without the torque sensor (cadence only) but it may have that option by now.
Grin's phaserunner/baserunner has a superharness that very well may connect to your existing display.
The controller is easy to program considering the amount of things it can do as well, and excels at compatibility with various PAS and torque sensing things.
VESC is a great controller, it's what i'd chose for >2kw builds every time. For less power, i like the phaserunner/baserunner.
Most controllers will require a change of the motor connectors and accessories.
I don't know Sing Yiu, but there are Lishui controllers that are labeled as Bafangs also, so I guess, Bafang is not producing it's own controllers, but buys them from different manufacturers.....
Thanks, that makes sense. Maybe “Bafang” controllers are just ones running their firmware and they put it in the specs to the manufactures that make controllers for their motors. If that’s the case, I can understand how the tool you mentioned could work across a variety of “Bafang” controllers, but probably only features supported by the hardware would be accessible/adjustable.
Their corporate write up says they make motors, batteries and controllers. Maybe a lot of that is through licensing agreements.
As Bafang mid-drives come w/embedded controllers, they most certainly are making a variety of controllers too.
No, think the Bafang tool only works with this CR.... type controllers. The rebranded Lishui controller has a Lishui firmware with the Bafang UART display protocol implemented.
A VESC based controller, and stancecoke's project to make Bafang displays compatible with VESC might work for you:
Not a good idea, as the LunaCycle implementation doesn't allow you to configure the assist levels for power and speed individually. No problem with a torque sensor, as you can simply reduce your own power to reduce the speed and motor power, but not the best solution for simple PAS users.
But I don't know, why there could be the wish, to have speed settings for each level. This very simple speed level controllers provide the most moped like behaviour, so the worst bicycle like behaviour....
Since the OP never provided a pic of his existing controller label or link when I asked, we have no idea if it’s a Bafang controller or something else (Lishui, Sing Yiu, etc). If it is a Bafang/CR controller, then the tool seems to be a good solution.
I plugged in the usb/ttl cable into my laptop and later in my phone with the usbc adapter, using the bafang configuration software and the speeed app, but the controller doesn't get recognized on either. However the battery is properly recognized. I have a rear hub bafang 500w and varstrom controller 9A (18A peak). What's the reason for not being recognized? And the solution?
I contacted Varstrom about their display since it was supplied with a 48V, 500w front hub motor (along with a no-name controller) and they stated that their system was user friendly only to change from US to Metric and top speed. They sent a manual, but it appears to me their system needs a password to change the top speed.I don't want to spend $300 or so for a display for a $200 kit,so I'll use as is.
I don’t think Varstrom makes anything. They appear to be a reseller that stamps their name on the products they sell. My TSDZ8 has thru pie name stamped on it. The display has a password of “2020” and can’t be changed. It would be a big coincidence if it worked on yours, but maybe worth a try.
KT controller and display kits are well documented, cheap, and have many settings you can configure/limit.
Compared to most users here, I’m a beginner. The KT system was my first change on my production bike. Wiring was easy enough since I’ve been wiring things and troubleshooting metallic faults for decades. The settings of the LCD8H are very easy to find, read, and set.
I recommend you find a pdf manual for which ever route take and review it BEFORE you make a purchase.
