offGridDownUnder
This is for discussing how to solve a problem. This probably isn't the thread about solving the problem yet - this is about defining the problem.
A primary question is what forum the solving thread would be under - I'm not certain of that yet.
The problem to solve is: how to run an EV/ebike/etrike directly from solar panels while still providing full use of regeneration braking from the motor. WITHOUT using lithium anything - supply chains break down, and I don't expect to be able to rely on a replacement lithium battery. A solution that lasts my lifetime would be best, or a solution that is locally renewable. Perhaps there isn't one - but that's the goal, or the best approximation we can conjure. Solar panels can last over 20 years - that's a good goal. I can easily mount 300W of solar panels as a roof on my trike (ignore getting it through the door then).
I do want to define a practical solution, or a practical experiment - no miracles.
I don't need to hear about whether this is practical or why not, I can tell the sun does not shine sometimes - that can be solved by adding some power storage (battery, anti-matter conversion, etc.) and that is another discussion, and mostly already known. I want to define what is the minimum or best for running off solar panels without muddying the solution so that the solution is well-defined.
Ignore the hills - assume flat ground. I expect we can solve the hills by adding more storage - that is not a part of the problem. The problem is defining what is needed not to charge a battery to then run from - but just run directly off the solar panels, and possibly without any battery at all.
Regeration will require some energy storage - or is dissipation better? - I don't want to constrain this so that ideas may be discussed. My first thought is super-caps, but perhaps SLA is better and achievable. Or NiMh. Or something else. Happy to consider real possible contenders.
Further questions are what types of motor/controller? I have Grin Base/Phaserunners, and hope that can work.
Again, first question is - what forum? @neptronix et al, please move this thread to the best place. If it's already discussed, please point me.
