Porsche "AC battery"... isn't.
bananu7
Poland
This is already getting posted as an "AC battery" that "doesn't need an inverter" but even the source calls it closer to the truth, which is a lot of small inverters on a lot of small standalone modules.
Seems interesting nevertheless, I imagine it would spread the controller heat more evenly across the entire pack.
Even better is not putting the controller heat anywhere near the battery pack in the first place (except for regions where it is so cold it *has* to be heated even while driving).
That said, I'm sure they had some engineering reason for building it this way, even if I don't know what it is. AFAICT, most commercially-produced engineering designs are compromiises between best design and cost of manufacture, etc.
Interesting!
Some solar panel installations use micro-inverters distributed across the array to create easy to install and replace modules, spread the heat, and reduce the impact of any one inverter failing. Maybe the EV manufacturers liked what they saw?
Interesting!
I think one of the main reasons for solar micro inverters is to not limit the whole system output to the most shaded panel which begs the question if you have a battery pack with a multiple inverters could you spread the load to not limit the battery capacity to the weakest block, potentially extending the lifespan of a battery. Probably very little gain there though.
Sounds to me like a solution in search of a problem.
