TRS300
Hello everyone. I've been reading from this site for some time now and I want to express my gratitude to all the smart information found here.
I'm working on converting my 2015 CVO street glide to EV. The project has guidelines and parameters one of which is that I can restore the motorcycle back to its original engine if desired.
Highlights of the project are that I retain full integration of the instruments, fob, abs, etc.
I'm using an me1616 that I opened up and modified. New bearings, varnish, new power leads separated to each set of windings. As a sub project I was curious to see if the motor could be converted to hall position sensors and I did achieve that using a suron position sensor with a custom magnet ring. It works well actually. I've run the motor on a simple sinusoidal ebike controller and it works fine.
I do have a Kelley KLS96601-8080NPS controller that I had the firmware upgraded so that it can be more easily integrated into the Harley CAN bus. The Kelley controller is huge however so I'm still on the fence about what controller I'll use. The good news is I can easily use a hall sensor controller now if I prefer to.
I posted this project on a harley forum and got zero interest. At least they did not call me names haha.
Anyway, going forward I have some questions that I hope to get some input on. And if anyone is interested in what I'm doing I hope I can help others on this forum also. Thanks for reading my introduction.
