Here they are.
OK, I've added the bytes to the torque table in
@bart594 's tool. I also edited the titles of the rows, according to
the link of
@Waynemarlow, knowing, that the speed ranges will not be correct. But better than to call them "levels", as it has nothing to do with the assist levels. To be honest, I have no idea, what this new parameter does....
I changed the fields for undervoltage settings according to
@DPC18RI 's hint, that they are now 16bit values. But this will only work for newer firmwares obviously, as the values seem to be showed wrong in the original BESST tool actually also. So don't use this version, if the values are shown correctly in the original tool! You will brick your controller!!!
I also found, that this values are read only on my controller. Perhaps someone can test, wether he can change the values on his controller.
Here my controller hardware and firmware version:
Bafang Besst software replacement for M500, M510, M560 etc - Commits · stancecoke/bafang_canable_pro
github.com
perhaps we should push the things concerning
@bart594's tool into an own thread...
Edit: new finding, I can change the torque table at runtime, and read the new values from the controller, but after a new start of the display, the old values are back
regards
stancecoke
