marqtte
New-ish here
- This is a kit that was installed 3 years ago and 6k miles on it. Up until now, zero problems.
- Bike is used in rain and snow occassionally.
- This kit was purchased through amazon and came with the BBS02B, 36V 500W motor. I can send a link if needed but most/all of the kits are the same.
- What works now: all buttons, wheel sensor, display (no errors shown), brake sensor, headlight, no unusually noises or problems
- What doesn't work: motor does not provide power to the sprocket (motor is not working) when either the throttle or pedal assist is activated. On occasion it does work for a few minutes and then it stops working. Turning the display off or disconnecting the battery sometimes helps but not usually.
- When it does work for a few minutes, it works fine. I get full power easily. No weird noises. No indication of a bad battery or a bad connection from the battery. All connections were checked.
- What I've tried: disconnecting brake sensor, checked all connections, disconnected throttle, tried a different battery, reset unit to factory settings.
- I suspect water got in the motor? Although there's no indications that seals are bad.
Any ideas? My next step is to take the motor apart and see if there's anything obvious. I don't want to buy a new kit and want to try and fix it first.
