I had a possibly similar experience recently :I'm not sure what happened to my TSDZ2B. After servicing the motor (oiling and greasing), it started behaving differently. Previously, in Off-Road mode, I could reach speeds of over 55 km/h.
Now, the motor shuts off at 41 km/h in Off-Road mode.
Too much mechanical linkage, I think electrical is easier.Isn't it easier using a small motor + 2 magnets?
What max wheel speed do you think you can run the 555 timer at that the display / controller will accept w/o error?Too much mechanical linkage, I think electrical is easier.
WIth a 26" wheel set in the display settings, I have to spin something with two magnets at 260 rpm to simulate 40 mph, and keep it next to the sensor for four days,
Nice that your OSF compatible LCD3 has odometer input. I have several LCD3's and another VLCD5 that I would like to set to the true mileage (I have logs), I guess I'll be pulsing them too.
Will find out. I think 40 mph should be feasible.What max wheel speed do you think you can run the 555 timer at that the display / controller will accept w/o error?
However, you have too many wires connected to the STM. You may get interference from the floating clock lead that is connected, You also should not be guessing any of the pins are depending on color.
I never plug more than 4 cables into the STlink. By variations, I meant that I vary the 5.01v cables the 3/5v pin options, with or without RTS.
I always have connected the STlink v2 flat cable sockets directly to the speed plug, (after first put some shrink tube around it of course), known as "poor man's connection". I only connect +5V, Gnd and Swim..... all these ST-LINKS V2 do not have the connections in the same order RST, SWIM, GND and 5.0V.....
This means you have a Swim connection. In that case imho you did this with the STVP Gui version..... I could read the 3 tabs and save them, but nothing else.....
Cable length matters. I once used a 1-meter extension cord for my own convenience, and programming didn't work. I disconnected the extension cord, and programming worked without a problem with 25-centimeter cables.Hi, everyone! I would like to start by saying that I am quite an amateur in this field, and this is the first time I have ever used a multimeter. So, I apologize if I say something silly.
Motor: TSDZ2 "half B" without throttle and a VLCD5 display
I ordered it from pswpower three years ago, so it's probably an old version and doesn't have any software restrictions.
The Java configurator keeps displaying the error code "device cannot be detected." The most I could achieve was that with the combination of GDN, SWIM, and 5V, on the fourth attempt in STVP, I could read the 3 tabs and save them, but nothing else.
What I tried:
I reduced the version of ST-Link v2.
Tried methods of RST, 3V, battery on/off, in every combination.
I suspected that the contact was not good, so I soldered a conversion cable, but the result was exactly the same. All I can squeeze out of it is the read option, again on the 4th attempt.
I also tried the write command several times, but it won't give in. I tried all jumper combinations and USB port options with the soldered cable.
I'm a little at a loss as to what else I could try. I read somewhere about specifically turning on the vlcd5, but also that it could destroy the entire system, so since I'm not an expert... I didn't want to try that option unless I received specific instructions to do so.
Could the wiring be too long or any other ideas?
Thanks in advance for your help.
View attachment 377487View attachment 377488
I have the Swim wire in between Gnd wires and a short cable (about 10cm). I use an 1m USB extension cable for connecting my laptop. This never has given any problem.Cable length matters.
Are you sure that TSDZ2(B) you have is not a German version with a V2 controller.
Search on this site it has been mentioned before, look here. TSDZ2 - When were the non OSF flashable controllers introduced? I have pulled a motor apart previously and changed a controller.Thank you for the replies. To start with, I'll re-solder the cables as short as possible, leaving only the most necessary ones. If that doesn't work, I'll move on to the other possible solutions.
In my case, "suspicion" would be a better word than "sure."
A stubborn damaged screw in a very bad place requires serious surgery, so the flashing project has been put on the back burner. However, since I had to take the whole motor apart, could someone confirm that this is a v1 controller?
