The lever resevoir was 100% too full, I tried very hard to push the pistons further, to the point that some fluid escaped the reservoir, thankfully it seems that the membrane let some fluid out but isn't torn.If your disc is dished "in" then I'd replace it even if it's still above max thickness. There are super cheap discs on Aliexpress nowadays, just get a nice matched set front and rear and plop in.
They also sell caliper rebuild kits, but I see you've actually replaced the pins. Greasing them properly and reassembling clean makes a huge change to how the caliper slides and works.
For the screws on the reservoid, it's not technically required to remove the cap to back out the pads - as long as the lever "preload" screw isn't set too tightly, it should be possible to push the fluid back in the level resting position. If the set screw is set too far, it could technically be blocking the return orifice, although I'm not sure if that's realistically possible. Always easy to try out by checking if the lever has freeplay. Even with a stuck piston trying to push the fluid back should push the piston out and allow the extra fluid to overflow into the reservoir chamber.
As for the disc on the picture it was brand new when I also changed the pins and the pads. I was expecting it to have to bed in but the pictures were taken after 40min/30km of MX riding, and the inner side of the disc is still not matched with its pad. Very disappointed, especially since I replaced the caliper pins in order to improve feel and make sure the disc and pads would be better aligned in the hope they would wear mire eavenly.
