yooper2001
⚡ Regular
Brand new hub motor from China (can't return) thumps when turning.
All gears teeth intact.on planetary gears ring and center
Gears are oblique and opposite direction of bafang. (\ instead of / on 35t) so parts are a month away.
To test if it was loose magnets, I powered it with the hub apart, and the clutch off, and it spun smoothly, no thumping. I put the clutch on without the ring gear and cover. I powered it up, and it thumped when spinning.
I reinspected all teeth are fine. (Including the metal center gear.)
Everything spins fine when I turn it by hand, but obviously it's slow.
The questions I have are:
1. Does a loose magnet need a slight load like the clutch to clunk?
2. Can the clutch be bad?
3. Could there be too much slop in the gears fitting to the center gear and it skips?
I think try a new clutch.....center gear...then check the magnets (which are a pain due to it having a mid shaft exit cord...and trying to push the cover off enuff to get a puller under will be a pain.
Can a clutch be bad and seem good by turning it by hand?
Thanks for reading this I was hoping on fixng it,..not spending more than the motor and waiting for more than a month each time to get the next part.
My ebike is my first, and although I am electronic savvy, I have no experience with hub motors. This was supposed to be my replacement for my current one, which I inadvertently must have affected the coils with a square wave controller, as it didn't quiet all the way down when I switched back to a sine wave controller. It's got about 1k miles, and when this 'new' defective motor is fixed...I will address the noisy one.
ANY advice would be appreciated!
