I don't know much more about it than what I wrote. Your ignition key would be in series with a switch that is closed by the BMS when discharge is allowed, and that would close a precharge contactor in series with a resistance connected to the motor controller, and then after 1-2 seconds, the precharge contactor circuit would open the main contactor (which would probably have a fuse in series). Apparently you can get contactors with a built-in adjustable timer as a side function, but I'm sure you could also implement the delay in different ways (could even do it manually with a three position key switch, but then don't forget to wait 1-2 seconds on position 2).
As far as I understand it (which is not very far, admittedly), it has several advantages:
- the BMS is not under load, which should increase its lifespan and remove some failure points
- the BMS doesn't get hot
- if the BMS gets fried, the contactor will in most cases close, but if the main load flows through the BMS, it might still conduct when damaged
- you can in theory upgrade the battery without having to replace the BMS (for example if you get cells with a better C rate)
- and of course, the main reason why it would make sense in your case: you are not limited to the amp rating of the BMS
I'm sure people who have actually done it and understand something of the matter like
@harrisonpatm can give better information.
I have looked at ANT BMS, and it seems the "small" 28S BMS are only like $50 cheaper than the large ones at the moment, so you probably wouldn't save much, if anything at all.
