Catatopatch
New here
Yeah it is, but dont we need a battery/motor/controller to showcase how regen works? Since its also the final proj showing how once you have these components and everything it would be actually implementable on a bike so it could be a competitive/cheaper implementation of regen for small EVs, thats also why if we could get this to work and have time left, we could make a clone of a controller or something like that which would have the bare minimum to showcase regen breakingMaybe I am missing something here, but I thought this was just a bench / lab demonstration of using an electric motor as a generator. Or do you need to build an actual bicycle with regen capability?
My groupmates also mentioned that we might need a microcontroller as well, they were looking at an ESP32 for that, for the controls aspect of this project dont we need a controller to like take the battery and convert it to the motor, as well as controlling the torque/speed by regulating the current flow? and then the microcontroller will be used to read the sensors, monitor and send commands to the breaking system etc?
"The microcontroller would be like the brains right, when it gets input back from the sensors and stuff, we would then give info to the VESC etc and based on that, like adjustments to voltage, current etc is controlled. The controller is the interface between the battery and motor, so for ex when the battery starts feeding, controller converts it to PWM and sends it to each of the three respective phases and then starts spinning, and then when we want the reverse to happen (break), the microcotroller can read that input, command the VESC to now provide negative torque, so then it would start resisting against the foward motion (becomes acting like genrator) and allowing the reverse flow back into the battery through controller. With the controller we then can also monitor voltage for ex, so lets say person breaks really hard while load is spinning really fast so theres a lot of energy, and maybe the battery is already near capacity, the microcontroller can let the VESC know yo bro lets cap how much we send back "
- From my group member on why we need both
