Top speed with a 72V battery running 12 kW peak and no body is 82 mph. It might go faster if my controllers didn't overheat. It feels deceptively safe at that speed, because the bike's components aren't really made for it, yet it doesn't feel dangerous. It feels well-planted and safe. It is not. A brake rotor bolt came loose and started acting as a lathe on the suspension block that mounts the right front hub motor. Luckily, I was only doing 15 mph with the motors shut off when it happened, otherwise that could have resulted in a very spectacular failure!
With just these front hub motors, it consistently does 0-60 mph acceleration in under 9 seconds. An additional mid drive powering the rear wheels could cut that to half or less. The front tires don't provide enough traction to make use of what torque the front motors can produce. I need to get some DOT rims and Mitas MC2 tires back on the front wheels. Currently running Alex rims built by Grin with Schwalbe Marathon Plus, and they're woefully inadequate for the speeds that this can reach. I was running Schwalbe Trykers earlier, but they delaminated and failed two weeks ago while the bike sat outside charging, after having been well over 70 mph that same day. I heard the sound of a gunshot while the vehicle was charging, a common sound in my neighborhood, but it wasn't a gunshot. The front left tire exploded, just sitting there.
I also had to panic stop from 65 mph on Missouri State Highway 141 last weekend, and that caused my front hydraulic brakes to lock up. I had to let the bike cool for 15+ minutes in the grass off the road before it would roll again. I didn't have regen enabled because of some magnet sensor issues, and that regen is absolutely necessary to prevent the front brakes from overheating.
Thus far, I'm very pleased with the direction that this build is heading in. Over-powered light-weight death traps are my favorite type of vehicle. Maybe I should buy a TVR.
