stancecoke
Minor legend
There's a quite big zipped firmware library in this thread, just check if your desired setup is in there...Any option to downgrade the firmware
So tested with different firmware , but all the same problem .There's a quite big zipped firmware library in this thread, just check if your desired setup is in there...
MMG5300C4819F801041.5 and MMG5300C4819F801007.4_500W |
| Hardware Version | MM G5300.500.C 1.0 |
| Software Version | MMG5300C4819F801041.5 |
| Model Number | MM G5300.500.C |
| Serial Number | XXX |
| Production Date | 2000-04-22 |
| Manufacturer | BAFANG |
| Hardware Version | DP C245.C 2.0 |
| Software Version | DPC245CF802281.0 |
| Model Number | DP C245.CAN |
| Bootloader Version | DPBF81.1 |
| Production Date | 2025-09-17 |
| Manufacturer | BAFANG-BAFANG |
| Customer Number | N/A |
I think we need a Wiki here also.my motor won't go past 24km/h
In no way so I blame this project or any of you wonderfully folkI think we need a Wiki here also.
Sadly the thread opener @DPC18RI seems not to be active here any longer, so we can't edit the first post of this thread.
So don't blame this project, if you can't tune your bike with the Canable. It's a matter of the bikes firmware, not of the CAN to USB adapter or the software to communicate with the controller
- The Bafang Canable Pro works with Bafang CAN systems only
- Most Bafang CAN controllers have a firmware installed, that doesn't allow any parameter changes by the user, you can read out the parameters, you can edit them and sent them back to the controller, but your changes will be ignored.
- There are tons of .bin files available on the internet, you can flash to your controller, but there is no overview, which firmware file allows which user settings.
- If you are using a M510, M560 or M820 you can flash the open source "EBiCS for Bafang" firmware, which allows full access to all relevant parameters. It's in a beta stage, so don't expect a perfect solution.
- If you are using a M820, you can flash the "FakeTaxi" firmware. This is a hacked original firmware with some improvements
I feel your pain. I am fed up with this Bafang throttle limit. So I am looking at the TongSheng TSDZ8 now.3 diffrent displays CAN programming cable and UART programming cable and no matter what my motor won't go past 24km/h so I quit I quit I quit.
I ordered a TSZD8 been wanting to try torque sensor for a few years since I saw TSZD2.I feel your pain. I am fed up with this Bafang throttle limit. So I am looking at the TongSheng TSDZ8 now.
Oh man, thanks. How far is this project?Wait for the M215/M315 open source firmware.
It should work already, but I have no M215/315/ BBS01/02 so far, so I can't test it on the bike.How far is this project?
I am here.willing to try it.
I have the bbs02b on standbyIt should work already, but I have no M215/315/ BBS01/02 so far, so I can't test it on the bike.
Next I will try to build a bin file, that can be flashed with the Canable tool, perhaps some beta (or even less) testers are willing to try.
I have the bbs02b on standby![]()
Here you are:I am here.
