endless-sphere.com
Can I ask you a question regarding the PAS (pedal assist) speed control?This is no limitation of the firmware, but the characteristics (Kn constant) of your motor. You will have to increase the battery voltage to get higher speeds.
You can check this with your lab power supply easily by varying the voltage at full throttle.
As written before. Don't test without load. The firmware controls the motor current, not the speed.Is there any way to fix these problems?
I received your answer regarding the PAS system, thank you very much!As written before. Don't test without load. The firmware controls the motor current, not the speed.
Without load, the max speed is reached with minimum current. If you don't want to test on the road, I recommend a roller trainer to apply load on the motor.
Third time: the throttle position defines the setpoint for the motor current, not for the speed.The throttle reaches maximum speed after only a small amount of movement,
Thank you very much! I'll read through the earlier discussion. I just thought the throttle sensitivity could be adjusted in the GUI.Third time: the throttle position defines the setpoint for the motor current, not for the speed.
We just had a discussion about the throttle voltage output in dependence on the throttle travel, there are throttles, that are only providing signal changes on a half of the mechanical travel....
As mentioned before, you don't have to read through hundreds of posts, but just read the WikiI'll read through the earlier discussion
throttle settings
Throttle offset
this is the ADC-value at closed throttle. Print out adcData[1] in debug mode, to see the value. Set Throttle offset to a little higher value to prevent the motor starting, if the value drifts a little with time or temperature. Read adcData[6] for the torque signal on AD1.
Throttle max
this is the ADC-value at full throttle. Set a little lower than the printed value to get the full current.
Entschuldigung Sie, ich bin wahrscheinlich kein aufmerksamer MenschКак уже упоминалось, вам не нужно читать количество сообщений, достаточно просто почитать Вики.
The Lishui Parameter Configuator
Free FOC firmware for Lishui E-Bike-Controllers. Contribute to EBiCS/EBiCS_Firmware development by creating an account on GitHub.github.com
I’m sorry, but I don’t understand how to perform the step for determining the minimum and maximum throttle values.As mentioned before, you don't have to read through hundreds of posts, but just read the Wiki
