bose said:It would be a bad idea to wire the VESC's in series...
Oh...thats's good to know. Thanks!
akiraEC said:Hi Benjamin,
Asking me questions when waiting for the VESC boards ...
Do you think the FET would benefit from having some more cooling ?
Maybe tying them to some copper or aluminium bar which would be to a aluminium profile ?
I see most of the other VESC are cooled and yours is not.
Is this something to be worried about ?
Slithr Boards said:Vedder,
I was wondering what your coefficient of friction was between the longboard wheels and the asphalt.
I am trying to calculate the necessary torque needed at certain grade hills, and this parameter, the coefficient of friction, has been uncertain.
Any thoughts?
Carl
Vanarian said:akiraEC said:Hi Benjamin,
Past 6S you will want a fan plate or a true fan like in a computer.
Vanarian said:I think this is not relevant to Vedder ESC, thought somebody here gotta have the answer. It is relevant to your truck and driving system models, plus the drag of your motors. Of course you can add the quality of your bearings and wheels, the grip rating etc...
There is a lot of factors to take in consideration to know how to calculate the friction coefficient.
Now for hills the most important thing will be the motor you want to choose and the amount of power you will feed it with. You don't want to load a 1000Kv motor the size of a longboard wheel uphill.
At stand start and at say 20mph coefficient drag is negligible too. You will want around a 200Kv or 100Kv motor to climb without fear. You will also want sufficient voltage for voltage gives you torque.
For a good example to follow look at the DIYers here and also the commercial boards, they have good examples of boards.
Vanarian said:Carl,
onloop said:i think as you go up in voltage there will be lower current & less heat, so likely less need for fan/cooling.... based on vedders video/testing i don't think a fan or large heatsink is required (i think he mostly use 10s or 12s)....but i guess we need to wait & see...
And of course it would not hurt to have it..
chuttney1 said:While it may not be necessary, I still think doing this type of calculation to factor in friction can help with calculating mechanical losses to help give a more accurate prediction of calculated speed using the equations provided from users on this forum when building an eboard. It can also help us learn what is the maximum KV value for a motor if the diameter of the motor's can did not matter. What is the maximum hill grade given a motor's size and KV and weight of the user?
Slithr Boards said:The friction coefficient between a longboard wheel and asphalt is a constant and does play a huge factor in the torque calculations for hill climbs. Yea there might be friction from the bearings in the wheels, drive train, and the motors, but since vedder has done the calculations as well as the testing to choose the right motor, then design his esc, he might have a good idea for the coefficient of friction I could use for my calculations. I was thinking around .25 ...
Carl
onloop said:Honestly I have no idea what you guys are trying to work out exactly... or why you would even need to know this to build an electric skateboard... Maybe useful for F1 cars... Also i assume there is no precise answer to this question because there are too many variables. Namely the surface quality of road & the density of the urethane..
If a particular setup doesn't get you up the hill do this.
1. Increase voltage
2. Change gearing ratio, keep dropping motor pulley teeth until you get to the top.
3. Increase teeth on wheel pulley.
4. Add additional motors.
5. Decrease wheel diameter.
6. Go lower KV motors.
7. Lose weight.
Fu*king around with formulas ain't got nothing on real world testing.
That is not true at all.I'll go from a visual estimation from pictures and say that till 6S you can go with a closed case as long as it has spare room between the PCB and the Cover. Past 6S you will want a fan plate or a true fan like in a computer.
update for all VESC BETA testers.....
assembly nearly done... just waiting on one part!.... Can anyone guess what part?
vedder said:Apart from the DRV8302 missing, it looks like the wrong shunts are used and that the sense pads on the shunt footprints are not connected at all. This will give either zero or a random value for the current readings, so as soon as you connect a motor and battery and try to run the motor, the ESC will blow up for sure.
vedder said:That is not true at all.
The current makes a huge difference and the voltage, kv and gearing decide what current you need for a given amount of torque. Since there is a square relation between current and heat generation, running at for example 80 A produces 4 times as much heat as running at 40 A. So if you have a given setup designed for a given top speed with 6s, changing to a motor with half the kv and going to 12s will give the same performance and produce only a quarter of the heat in the ESC for the same operating conditions. This is why I encourage to go for higher voltage and lower KV. A well-designed (motor kv, gearing) 10s-12s single motor setup with a top-speed of 35-40 km/h with VESC will not require additional cooling even if you climb hills, but a setup with 6s and the same top speed will require additional cooling for sure since 4 times more heat is produced in the FETs. Notice that the top speed is an important factor and also notice that the top speed I'm talking about is at the maximum speed the motor can reach with the available battery voltage (running high voltage and only using half throttle does not help at all). If you design for a top speed of 20km/h or less, you can probably get away with 6s and no cooling.
Even if you have a board with very high theoretical power output, the top speed is what decides how much torque you need for a given acceleration, and the gearing and motor kv decides how much current you need to generate a given torque. If you have a 6kw setup designed for 40 km/h, you will have a very high acceleration at full throttle, but there is no way that you can draw that much power continuously (meaning that the high current and thus high heat generation only come for a couple of seconds at most). The only way you can output that much power continuously is to design for a very high top speed, and then you need high voltage and/or dual motors and/or cooling. It is also important to understand that if you gear for high top speed, the losses will be higher even at low speed since current is what causes the heat, and at low speed you will have higher current and lower motor voltage for a given torque than you would with gearing for lower top speed.
vedder said:If you start going downhill and brake a lot on a full charge, the battery can take damage. There is not much to do about that. In fact, it is difficult to make non-regenerative braking on electric motorsHow do you protect the battery from being overcharged? What happen if you start braking with a fully charged battery, will it still brake?One possible solution would be to connect a load to the battery that starts to burn energy if the cell voltage increases too much.
