chaka
Long motor wires are fine. 2000uf of capacitance is usually safe to go 12 inches in battery wire length, you could probably push this a little.
chaka said:High output VESC!!!
jacobbloy said:Introducing the dual VESC made for simplicity.
Foreseen problems:
3v and 5v Power rails not supplying enough amp
Batterie input traces not handling required current
Added cost of 6 layer pcb
Vanarian said:ChakaNice unit but apart from heatsinks I fail to see the difference, is there thermal past applied to transfer heat?
This unit is what I ride on. I usually ride with a constant output around 800 watts. Without heat sinks I was getting thermal shutdown after extended high output sessions.Dr_T said:Weren't the shunts the bottleneck of output? Or did you change those too?
This is a twin ESC designed and based off of the VESC 4.10.
Benefit:
compact design when compared to wiring 2 vesc to gether
Less soldering and wiring
Batteries input is shared between both ESC
Capacitors are pcb mountable at 45 or 90deg
Both ESC connected via can bus
1 USB input
Built in nrf24l01 footprint ready for nunchuk control
Reduced componants by
Both ESC share 3v and 5v power rail
Both share the 1 set of LEDs
And again 1 USB and reduces the need for installing jst plugs meaning a small componant reduction.
Foreseen problems:
(Please add more)
Ways we have tried to fix:
Made pcb 6 layer to allow 3layer thick power traces
okp said:Hey,
I got my two new VESCs installed using CANBUS on my upcoming e-MTB. Everything is fine except that I got an error code : OVER_VOLTAGE
I am using four 3S 5AH in series to get a 12S 5AH with SK6374 168kv - dual VESC with CANBUS. PPM set on VESC ID 0.
I got my settings on BLDC set to Voltage limits
- Minimum Input : 8
- Maximum Input : 50
- Battery Cut Off start: 40,80
- Battery cut off end : 38,40
My currents limits should not affect this error code
- Motor Max : 60
- Motor Min : -60
- Batt Max : 60
- Batt Min (regen) : -20
- Absolute Max : 130
Anyone got a clue about that?
That's quite normal if you're using them without sensors. Enjoy your ride!okp said:By the way. I got a hall sensor detection error on the motor detection. Never noticed this error, but I assume it is because I don't have any sensor on these motors. The other two values are well detected. 1200 & 120.
chaka said:We have a shipment of VESC compatible vertical usb ports on order so we can make this happen. Looks to like we can save about 10mm in width by sticking with Vedder's original design!
