FM,
I would think a potential material would be the graphit re-enforced plastics simular to what's used on current hi-end rc car chassis might be alright for a chain system I have designed. (I am with LFP when it comes to stifness for a real gear 2 gear tranny though). I really doubt there will be a high enough demand to look at that option regarding trans cases. Given I can make the match plates for a production foundry to cast these by the hundreds, I hadn't considered plastics as an option. I am going to make a carbon fiber unit just for looks soon enough though. Thanks for the sugestion though.
12p,
You seem very interested in the machining procecess, A budding tool & die hobbyest?
given I need to make accurate holes in qty. to fit these bearings, I made a series of mods & some new tools to do just that.
step 1) Is of course locating the first hole & clamping everything securly. Careful layout & wigglers work fine.
2) drill a pilot hole to depth. The pilot hole dia. is determined by of the chisle point of the next tool
3) drill the next rough dia hole to depth. I modified a 1"dia. drill bit for a very shallow point
4) bore the final dia with the boring tool. (this one is made to length to fit this set up & matches the
other tool lengths to ease tool changes without disrupting any positioning.
Here is a picture of the tools in sequence:
the block to the far right is a simple setting gage to allow tool sharpening & repositioning back to correct.
diameter.
here it is in use. the tool body is .75" cold rolled steel. a 3/16"sq. lathe tool cut & ground to fit,secured with 2 10-32 set screws.
