John in CR
100 TW
Here are some interesting things I found at SurplusCenter.com :
$20 3-speed transmission for riding lawnmower. 7:1 low to 4:1 high http://www.surpluscenter.com/item.asp?UID=2008120104583171&item=1-2950&catname=powerTrans The unit itself looks pretty compact at about 4"x3"x1.5", and after whacking off much of the shaft the shipping weight of 7lbs can probably be reduced to about 5lbs on the bike. That seems well worth it unless you're going for an ultralight build.
$20 5.25:1 aluminum gearbox reduction http://www.surpluscenter.com/item.asp?UID=2008120104583171&item=13-1064&catname=powerTrans
$5 one-way bearing and friction roller http://www.surpluscenter.com/item.asp?UID=2008120104583171&item=1-2317&catname=powerTrans
$5 steering U-joint. I was thinking this might work for the joint in the steering at the front of one of those Ground Hugger recumbents. What do you guys think, do U-joints exist that have no "slop", because I can't imagine any bike with any amount of play in the steering? http://www.surpluscenter.com/item.asp?UID=2008120104583171&item=1-2737&catname=powerTrans
Some of their electrical stuff may be useful, but I'll leave that up to the e-gurus around here. One thing I've wondered is if U-joints can be joined together in series to obtain a 90° bend. I realize it would need a bearing support in the middle of the series, and U-joints have the issue of somewhat discontinuous rotation, but if you had say 4 in series at different rotational positions could that make the motion constant enough for our purposes?
John
John
