mechanerd
- Joined
- Apr 8, 2013
- Messages
- 11
I'm an electronics geek, love motorcycles, atvs and snowmobiles. In the past 15 years I have run across my gamut of used and abused vehicles and witnessing some scary opportunities for electrical shorts and fires. So, I'll toss my advice on here in hopes of helping. I used to be an IT guy who services mainframes, server clusters, and the typical batch of retail bench repair nonsense.
I'm helping a distributor for e-bikes in the 450W range for an Anglican church ministry in Vancouver, WA USA. Using simple frames and AGM batteries.
1. Wrap your harness, it's basic and easy to do. Secure that wiring with tape for water protection, and adding some abrasion resistance. Zip tie were if flops and moves from vibration to prevent chafing and flex breaking of the wire strands. Leave about 1/4" of the harness exposed for testing and identification of the wires by color code if you like. (Don't get me started about chaffing and the aircraft industry problem..)
2. Whenever possible, use tin coated copper wire. Nothing like stripping the wire and finding green oxidized copper wire that ask as a free heater unit to your circuit. The water and air gets under the insulation, and makes the wire brittle. This is a long term problem and will get you eventually. Use silver wire like the old aircraft of WWII for high amperage and high voltage sections. That leads to number 3.
3. Coat the backside of the Molex or nylon connectors with RTV silicone, Permatex black, to prevent the pins inside from getting wet, and keeps the pins and their retainer tabs from moving around. To date I have replaced hundreds of bent pins, loose pins, pins that fallen out of the connector, and we are talking about cheap Chinese pins that was sometimes a bit on the thin side for the voltage and amperage going through the circuit.
If you accidentally immerse your machine in water, or have an exposed loose conductor, it's hard for it to arc to something else, if all the other metal bits are coated. Even a couple plies of cheap electrical tape has several hundred volts of insulation resistance.
4. Heat shrink is your friend, heat shrink with RTV squirted in there before curing adds strain relief to support the wire bundle before it goes into the connectors. Sort of an impromptu molded cable. Heat shrink with adhesive lining which is a bit harder to find, is just as good. 3M is not the only supplier, there are plenty of generic suppliers. Get a simple $14 heat gun at Harbor Freight to get it right.
Cooling:
5. Get some airflow around that controller, it might make the difference in the long term to save your precious transistors. The trick is not having the biggest metal heat sink on there, but how fast you can draw the heat from it. Airflow helps the metal get rid of the heat.
Think about a small DC fan to push air from a small hole in the front to the rear of your controller/electronics. Just like the PC industry learned, the first Pentium processors were woefully melting and re-flowing the solder on the neighboring video card and sometimes thermally cooking the voltage regulators nearby. Hot and cold cycles break wires in cpus, transistors,
Extreme Mods:
Copper shims to draw the heat from the transistors to the heat sinks. Look at the Pentium 4- 4 core and better heat sinks for PCs. Duplicate it.
Oil cooling is an option for controllers on sinks that are sealed. The high end gaming PCs went to the old school of copper sinks and water cooling.
I doubt the controllers need a pumped system with a radiator yet. But, I bet there is someone out there with a 8-50 kw controller that might need that.
If the heat sink is just warm to the touch you are ok, even better when it's at room temperature.
http://www.youtube.com/watch?v=6sP45uBj4-k
Thanks megacycle for the fuse chart. It was informative. I am still not sure what size fuse or breaker to put on a 450W 48v or 60v bike that is only pulling and average of 10-30 amps since the controller is pulsing the motor. I think I will get an o-scope on the B+ wire and see what's the average current and size the fuse and breaker from there.
Cooling:
Extreme Mods:
