They can explode or catch on fire for no apparent reason. Always charge where such a fire won't cause massive damage. Compressing the cells is good. Putting all of them inside of some kind of metal can is good.
pbrownhg said:In my investigations, an Italian contact has brought to my attention that he is using Lithium-Ion batteries from a Chinese source with good success. The batteries are 32aH cells with a 10C cont. rating. the cells are 820 grams each and cost $32 USD each. For my 24 cell configuration that is only $768.00 USD. This sounds like an amazing deal. Can anyone throw words of caution?
dnmun said:you can adjust it later if you wanna change the final voltage. it requires the full voltage 4.2V/cell (100.8+)to balance the pack under the BMS but if you don't want it to reach full voltage, just turn off the charger when it reaches the voltage you want.
i recommend not charging the battery until you need to use it. leaving a battery charged 24/7/365 is how they end up with short life cycles.
