Some wiring changes:
1. Putting all the diodes in a waterproof box, instead of in the battery boxes. This allows the four battery boxes to be compeltely interchangeable, and interchangeable witht he old electric bike. Them things is ixpinsive, better share them among as many uses as possible. Cast aluminum boxes should be quite durable, using them for custom lighting as well as terminal boxes.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_11965_-1
2. Lights will come off of two diodes connected to the two lower-voltage batteries, instead of jsut one, to avoid draining one side more than the other. I'd power the lights off the top of the 72V stack, except I had a hard time sourcing DC-DC converters that would take that much input voltage and didn't cost a mint.
3. Struggling with the idea of using stock 30A anderson connectors, vs. heavier 75A andersons. the bigger andersons are bulky, which is not an asset, but John Robert sez they hold up longer. So far, the original e-bike is holding up pretty well with 30A Anderson connectors, so maybe I am overthinking this.
4. Going with 10 Ga conductors for the combined battery power leads, as two batteries can supply a helluva lotta current, and I am worried that 12 Ga would be too light. In house wiring, 12 Ga is only good for 20-25 amps, and we E-bikers seem to push it to 30 amps pretty regularly. I'll use "primary wire" from an auto parts store, as it is flexible with thick insulation that is oil resistant. Eventually all the wires will be covered by split tubing or shrink tubing, to keep them out of the sun and provide double insulation.
5. Found a deal on a DC-DC converter designed to control LEDs! This is an evaluation board from Maxim intergrated circuits (not the Maxim that is a magazine just a tad more decent than playboy!) that can be configured as a 350MA LED driver, hot enough to power a really bright Cree LED headlamp.
http://www.maximintegrated.com/datasheet/index.mvp/id/5975 I decided to get the eval board instead of buildign it from scratch, as I have enough interesting things to build right now. Of course I could just buy all this stuff from Ebikes.CA, but I am trying to push the envelope to make a light that is about twice as efficient as their already-miserly
1000 lumen headlamp http://www.ebikes.ca/lights/
In other news, I bought a bunch of chain at a local bike shop, only to realize that the intermediate cogs I used were off an old Sturmey Archer 3 speed, and were 1/8" width cogs instead of 3/32". Regular multispeed derailleur chain won't fit the cogs. I'll eventually buy some new 1/8" chain, but just to put it together I used a bunch of old chain from the Bike Mine in the barn. I found out to my chagrin that it is possible to assemble bike chain into a mobius strip, instead of the standard loop. It would only fit onto the gears in an "X" shape, the front gear having to turn backwards to run the back gear forward. Next time I hit the shop I'll fix it. Recumbents take at least 3 chains to get to the back cogs, its a helluva lotta chain.
Got tires and gears installed, so as soon as I get the chain fixed I can take it out for a people-power-only spin. I'll order good Schwalbe Marathon tires later, right now just running on junk tires from the Bike Mine.
Terracycle http://www.t-cycle.com/Merchant2/merchant.mvc order just came in! I have two return idlers, and a WGX fairing. I may not need but one idler, but this is a part I want to have around, as it is always part of a recumbent design. The fairing is sweet - Flexible clear polycarbonate, molded into an aerodynamic shape, pre-drilled for mounting. I declined to buy their expensive mounting bracket, since I already built a frame the mounting bracket didn't seem like a good value. I may have to design a swinging mount for the fairing, as it may be hard to get into the bike without a "door". I'll probably fake one up out of conduit and zip ties to get the fit right. Part of the mounting bracket will include a dashboard (handlebar-sized tubing right up in my face) for the Cycle Analyst, and other instruments. There will at least be an old digital watch clamped around the handlebar, as I always want to know what time it is when I am riding somewhere, maybe a way to hold a music player or something. It would be easy to add a cell phone charger, and I will need buttons to turn lights on and off. It would be nice to have a horn. It would be even nicer to have a horn that plays the song
"Electric Slide" by Nevile Livingston http://www.youtube.com/watch?v=JFMtBibwrgY
Yes, that is possible in the 21st century. Welcome to the future. Although the song is just as bad as Rick Aston's "never Gonna Give You Up", I still like it, I am embarrased to say.
