docnjoj
1 GW
That really looks quite clever, #1! The frame makes it possible to avoid single sided hubs, which is generally a good thing.
otherDoc
otherDoc
In Naeem's case, I'd advocate using Blender and GIMP (for image-edit/creation). While not CAD, Blender can model, render and animate with IK... suitable for accurate scale work.x88x said:Wow, that must have been a pain to make in paint, nice work. Someone get this man a CAD program, stat!
amberwolf said:It looks like it should work, as long as you have a joint at the steering tie-rod to tire frame that will allow tiliting to the angle required, but will not flop around, thus leaning only when actually steering.
If I were doing it, I'd build a little wooden or plastic model of sticks first, to see if it physically operated the way I wanted, before scaling it up to the actual item. I've had a few ideas for steering and suspension setups taht as soon as I started to set up a physical model of them I realized they couldn't work the way I wanted them to, even though I saw no problem on paper.
numberonebikeslover said:but there is this power failure which may last for hours. So thats it for this weekend I think.
chinmay said:hello naeem,
thank you brother for inspiring me. i m from India and also doing a e-trike project but was worried about the finances. but seeing u in action has given me a good hope. i did specially like u r cvt project and the way u used that old fan motor.
thanks bro
lifepo4ever said:i just read all your see all you video of your bike and what i can say .. i was so amaze by your work i am speechless .. and you make my day your imagination is endlesss in the sphere Promise me to never give up of what you do it !! the world need more brilliant man like you to help to save the planet, your my model and you give me so much positive sense of my life !! simply the best story on ES
torker said:So good that it is driving well. Good to get your feet closer to the pedals. Now it should climb better that you can push your lower back into the seat. Love your double o cycle pic or This calls for a new video=riding=scenery :wink:
Gordo said:Naeem;
Please put your guard and handle back on your grinder. I know it makes it harder to use, but fingers are hard to replace.
A glove is a good idea as it cleans the blade before it rips through your flesh.
Keep up the good work. Very interesting build.
