Hubs have one gear. That's their shortcoming and their strength. You pick the battery voltage, motor RPM per volt, and controller amp limit to match your wheel diameter and desired cruising speed. If you get it right, you have optimal efficiency in your most prevalent running conditions. You'll give up some top speed and climbing ability in return for being better at what you do most of the time.
Also, you will get vastly increased pedal drivetrain life rather than vastly diminished endurance as with a crank drive. And you will have redundancy, so the pedals will take you home if the motor fails, and the motor will take you home if the pedal drive fails.
Most high dollar commercial e-bikes are crank drive for a reason, and it's not a reason that works in your favor. They want you to report back to the dealer often with worn out parts and breakdowns, and they want to to replaced your busted bike with a new one as soon as possible.
How much of a sucker are you? Only you can say.
BBSHD at least has the advantage of being somewhat intercompatible and hackable, but only if you don't get one of the CANBUS versions, that trap you into their parts ecosystem.
