Cyclomania
So after disconnecting the BMS from my faulty battery it seems I again get a more correct reading. But it seems the cell groups are now 3,4 or 3,5 and one of the 13 cell groups is at 3,2. Issue that arose with this battery was that it was showing 37 volts of charge, when the bms was still connected. But when it is now separated from the balance leads the main negative and positive show a more correct reading of 43 volts for the entire pack.
Can I use an active balancer, made for a 13s-pack, to charge back my cell groups into balance again?
And after that I could try to connect the balance wire-connector(now separated from the BMS) back into the BMS again?
Or do I have to disassemble the cell groups not in balance and balance every cell individually?
