The source has to go to the switch somewhere. I don't see the connection.
izeman said:source goes to battery negative and to the right pins of the fets. or do you look for something else?
i don't get itfechter said:It's hard to see the blue trace in the layout. If it connects to the zener, then it would be OK. To me it looks like it isn't connected. Everything else looks good.izeman said:source goes to battery negative and to the right pins of the fets. or do you look for something else?
i guess 0805 should fit as well. those are the ones i ordered http://www.ebay.de/itm/171346154762rmrf said:Can't find 1206 zener on mouser. Any other package that would fit?
i don't know if this is true for ALL TO-220 cases, but at least it is like that for the 4110 and 3770 we use here most often. that is why there is an insulation layer between FETs and heatsink/case. we don't need that in this case, as the two FETs share the same level. but be careful if you connect it to your bike's frame - i did that to cool the circuit. my battery is NOT connected to the frame, so this is no issue. but if you (for whatever reason) decided to use the frame as common ground you will not be happy, as in this case you connect SOURCE = battery-gnd to DRAIN = controller-gnd and this makes the circuit obsolete.rmrf said:Thank you for explanationI didn't know that backside of a FET is also DRAIN
