GreenRoad
madin88 said:striker54 said:I'm running 22s Lipo. Ok, I didn't think in that. Maybe the diference is in the voltage, but i can assure that there is a big diference in performance between running with the autodetect settings and after doing the manual tunning. I will post the settings when I get at home, but I think that the settings from one motor aren't good for other motor even when they are same model, because there will be always small differences in the production of the motors.
LiPo has flatter discharge curve and higher nominal voltage and this will make a noticeable difference in speed.
i also do not use all autodetect settings. indtiming and anglecorr i let as is is, but PWR timting i changed..
waiting for your post
yes autosettings are not allways the best
indtiming and anglecorr - i quiet okay - but i try always one value down/up an check the current on the display.
Its good to check the values on an "load".
As i told allready, it would be good to have an list from us adaptto users, with the used / programmed adaptto settings - so it would be much easier to compare our values together - and find the right values...
Its hard because everybody has to try his own values to find out the right settings...
