"I would like to upgrade the temp sensor in both of my motors. Does anyone know if a KTY 83 or a KTY 81 is better?
Does anyone know what comes with the Max-E?
Thanks."{offroader}
+1 im also interested to know what t sensor comes with the controllers, as im bout to try doing some mods to cromotors...
Offroader said:
What kind of packs did you wire into the bms, 6s,4s? Did you splice any wires to make it fit into the bms?
I'm just curious if it was somehow related to the way you had your battery wired in a series or had it wired. I've yet to hook up my bms, but with 6s packs I heard you can damage the BMS in certain instances.
i know how easy it is to f**%k up soldeing the ballence plugs, but the strange thing is, i have checked all the pins on all the plugs before i plugged them in to make sure they all increase in voltage in right order, also when the board had the issue, i rechecked that plug,#3, and all was ok. finally, the plug worked just fine the way it was in another board when i reconfigured them to miss board #3
so by deduction id say its definately not the way iv soldered the ballence wires.
pack is 2 blocks of 10s10p 18650 25r, so its pretty neat and tidy, just a single series connection between the 2 blocks, and the power leads to controller.
there are 2 ballence wires that bridge the packs with a small plug so you can detatch them when the packs are separated.
its for cells#11and #12, as you have 5 boards for 4s so it wont split in half in descete units of boards....
could it be possible that having the main series plugs between the 2 x10s packs connected or disconnected independently of the 2 ballence wires that bridge them could fry something?
if so that could make sense cause it was that board that died....
another odd thing, when i first plugged in the bms all cells were ballenced to 0.008v . now, thats changed to 0.047
(stable) without any discharge of the pack that i know of, the next day!
on the bms screen, its 2 cells that are doing this on cells 7and 8 on board #2. one is slumped lower to 3.600 and one is spiked high to 3.647, the others are all pretty much flat like from the start, around 3.623-3.627
i remember when i first plugged it in yesterday i was pleased to see how flat all the bms barrs were....
Artur said:
ridethelightning said:
im having a little trouble with the latest bms im installing.
all wired correctly(this is the third one i have done now) and was working ok. i unplugged it to re-arrange the pack housing.
when i plugged it in again, i got BMS warning and one of the boards,#3 is showing "fail fail fail fail" in the batt monitor, and there is a little red light thats lit up on it.
checked the plug, its all fine.all reads ok on the meter.
then i reconfigured the boards so that i skip board #3 and it all works fine, no warning and voltages all show up in the monitor.
so at least the bms will work ok, but im a little miffed that this brand new bms board does this. :|
so looks like board #3 is either faulty from manufacture or has been dammaged somehow.
anyone know what could have caused this and if the bms have warranty on them?
thanks.
I had similar problem when I re-connect my pack and made mistake on soldering... Red light.. Hot board... I did what you did, resolder it and use another free board connector. No problem so far.
what exactly did you solder wrong in what order to do this Artur??
would be great to get some more insight on the bms so we can all avoid making mistakes ,learn the do's and dont's.
any hints from the adaptto gods here? :lol:
