ridethelightning
- Joined
- Jul 21, 2013
- Messages
- 2,010
in that case i would be interested to see also
Wheazel said:To me it sounds like a bad connection, or some component that is glitchy. Can a hallsensor act like that if its about to break down is the the question...
Otherwise I am thinking the wiring or solderconnections in the waterproof connectors. Checked that?
I had the same problems almost exactly as you're describing with my Clyte 40110 motor. The Adaptto diagnostic screen showed my halls working fine, also..... I replaced the stock Clyte halls with Honeywell SS-41's, problem solved! It seems to me the Adaptto controller doesn't play nice with Clyte motors!? Did you experience any "drag" when accelerating from a standstill? That's how my problem started....MurderousFrog said:Thanks guys, I checked all the connections and they seem fine, tested them with a multimeter.
Checked the individual hall voltages as well, they jump from 0 to 4.12V and back, which means they work, right?
So I guess I'll order some halls and swap 'em out just to be sure. I still had the original ones from crystalyte in there.
It just seems weird to me that the problem started occuring after not touching the bike for 2 days, although it worked fine before...
skWarDog said:I had the same problems almost exactly as you're describing with my Clyte 40110 motor. The Adaptto diagnostic screen showed my halls working fine, also..... I replaced the stock Clyte halls with Honeywell SS-41's, problem solved! It seems to me the Adaptto controller doesn't play nice with Clyte motors!? Did you experience any "drag" when accelerating from a standstill? That's how my problem started....
Allex said:Could be moisture in the system(controller) as well?
Jestronix said:I,m set on buying one of the new v2 units, reading this thread I see lots of problems. Being a forum often u often get people showing up with problems. I'd be interested in hearing how many are having no problems at all and highly recommend them. I know there's lots out there, I suspect we are looking at a 1% to 3% failure rate ?
Boestin said:Finally, the Cro is working!! I replaced the halls with Honeywells SS41... 16,5KW with stock Adaptto![]()
