ccmdr
Well a house with a cellar, a large one and large tools with a bench PSU... Envious
:lol:
Your bob on, the Adaptto page is saying exactly as it should with a 0,1,0 H1/2/3/4/5/6 etc... It definetly is having problems with phase and Hall detection if it's running SLESS fine.
Seeing as you've checked each individual Hall sensor with power on and rotating the wheel, btw did each hall measure 4.36v like the video, from what I could tell the voltage shown was just the VDD voltage?
The Halls do have to be setup correctly in sequence, I've read about that previously in this uber thread. The Adaptto wiring diagram does actually show which Hall should be which, it just means pulling a cover off. However, your video shows a clear H6-H1 countdown indicating the sequence is fine.
Have issues myself with 'Autodetect' and the Cro v3, but not the HS3540. Sometimes have to 'stall' the Cro at 'Autodetect' for 5 seconds and then let it continue as norm. As in mount the wheel on your bike, put the bike on a stand where you can 'see-saw' the front and rear wheel off the ground easily. Sit on the bike, lean back (stall the hub), start 'Autodetect' 5-10 seconds (stall) then lean forward (release stall).
I think you'd need to check the hub and controller separately, do you have the ability to you swap either motor or sensored controller?
Btw your V2 Cro should have 2 sets of Halls, have you tried both? The Halls are 120Deg apart so thats not an issue.
