alexplatts18
- Joined
- Apr 18, 2019
- Messages
- 26
Does anyone know where I can buy this stem from?
Sent from my CLT-L09 using Tapatalk
alexplatts18 said:Has anyone made a parts list for less experienced individuals that still want to build an ebike? Preferably ( between 5kw 12kw)
Any help will be appreciated
alexplatts18 said:I'm an Electrition so I have a decent amount of knowledge on the electrical side of things. I previously bought a 12kw ebike. I would now like to build my own. I've already bought a 70A controller 19inch wheels with the hub driven motor. I will probably build it off the enduro frame. I'm looking at the 72v battery would buy one rather then build it at home.
Hi I have exact the same symptoms I ran the test and was getting 4.28v across everything cable so I connected between the red cable and every other cable.Jeremy Harris said:OK the plug you took apart is the Hall sensor connector. The red wire should have around 5V on it, the black wire will be 0V and the yellow, blue and green wires are the outputs from the Hall sensor.
If you are very careful not to short anything, you can test the Hall sensors like this.
1. Connect the Hall sensor connector to the controller, but for safeties sake leave the three way phase connector disconnected.
2. With the back off the Hall connector (as in your photo), carefully connect the meter on the volt range between the black wire and the yellow wire. Make sure your meter probes don't short any of the connections.
3. Turn on the power to the controller and don't touch the throttle.
4. Rotate the wheel slowly by hand (or get someone else to rotate it if you're holding the meter probes steady) and you should see the voltage on the meter switch from 0V to about +5 V several times as the wheel rotates. If it does, then it means the Hall sensor on the yellow wire is working OK.
5. Repeat this test for the blue wire and the green wire. If all three wires show a switching voltage as the wheel is turned then you know that the Hall sensors are working OK. This means the problem will be somewhere else and we need to think again.
alexplatts18 said:
There's no attachment. You'll need to follow the directions here to attach an image:alexplatts18 said:Hi, Could someone tell me how to connect up a sabvoton svmc 72200 to a cycle analyst. I've attached the controller wiring diogram below
Obviously it isn’t. I mean, it could have the same wire colors and still be connected differently inside. Shutting off the CA screen when plugged is something to worry about about a short.alexplatts18 said:...The cable connection is exactly the same as the Last throttle aswell.
Any help would be appreciated!
