deffx I think you and Pendragon bout the only ones that understand me...
Yes, to most things you said.
Finally my fingers are not so scared of heat so I pulled out the solderer and
Today I soldered on 5.5 bullets onto the EFC (elfuckocontroller)
twas like 40 degrees in brisbane ................
did some more bodgy plyer fin destroying on my abs case.
Flipped an aluminium bracket and old mate Jon across the road got interupted from rose pruning, to borrow his in the front yard vice, to flip straighten the bracket.
everything kind of fit.
sparks on this battery man
I only got my old two short bungies which I kind of reworked to sort of hold the battery down there / legs do the rest.
zip tied (bloody to short) so had to use like three to do the job of one zip tie all over the controller and other elf (el fucko) style garet building.
And then in 40 degree heat I went on the elf not so virgin ride, but at least virgin with headways on her.
I rode down to the bottlo 9 picked up 8 beers from the tuckshop bin, rode to fam and back after a few reshreshments (and thunderstorm approaching)
so how does the old tank ride?
grumble grumble.
top speed same as my main bike (or atleast main bike with the headways)
grunt (not there)
peddling (wow for having a big black box between my legs you could call me a sheila, but because its hardtail and the drivetrain is perfect - peddling was lovely for the few seconds I could be bothered with it in this heat)
Af (ass factor) I felt every pot hole a bit too intimitate on the rear. It was a great experience just to make me realise how spoilt Ive been with FS.
BIGGEST THING TO WORK ON
I need an on off switch because the headways have a seperate charging terminal and when I go to the shop I didn't turn the things off because I dont like sparks.
so yeah, i got an old cow of an ebike as a back up.
