John Bozi
Pendragon havent seen you around here for years!
that's not my bike pictured, but that guy ruined another hub with his first try but the crystalyte hub he got is meant to be stronger.
There's way too much debate about rewinding still, just follow john cr, anyway I was going to buy a second hand one and try but man it looks incredibly complex it just put me off because I doubt Id do a better job of it...
the wrong gearing doesn't get solved compared to say running in granny gear.
I am about to pay for the bafang 750w, It has 1000w peaks, this is double what a drive train can handle in my opinion already, so yeah will be real careful at first until I piss it up ....
Actually Pend, you probably have idea of gearing with all your mid drive stuff recently.
I'm trying to find a suitable rear sprocket solution. Because once I apply 1000w to the thread on cassette there will be almost no chance of turning back...
I've read a bit on sheldon brown http://sheldonbrown.com/freewheels.html
wondering if there is a way to get our thread on hubs work with splines because most products these days are. this 42t sprocket im guessing cant be run single speed? but its spleened for example
oneup
Our 4065 has M35 thread http://www.crystalyte.com/Dimensions_H40%20Series.pdf
studying sprockets I need to know chains: from wiki
Another thing is replacing my custom cut cranks
worried that these cotterless wont fit right, from sheldon:
white industries single freewheel for trials
.The standard ISO threading for freewheels is 1.375 x 24 TPI, the same as for standard ISO bottom brackets
Chains with 3/32" wide rollers are used on bikes with derailleurs such as racing, touring, and mountain bikes
Traditional cotterless cranksets use a tapered square spindle (axle) end. The sides of the end taper at a 2 degree angle compared to the centerline, 4 degrees compared to each other.
