Well I did my first unassisted ride on the Greyborg. It's a not "too" bad to ride unassisted, if you like going slow and working really hard. Down the hills was awesome, and a good indication of what it will be like to ride one I get the batteries in.
It is a heavy pig but rolls quite well. I was surprised at the lack of cogging / drag from the motor, My last bike (a 1kw Conhismotor kit) seemed to drag a lot more than this one. but that was a while ago.
The rear suspension is like riding a trampoline. There is NO... None... Nadda.. zippo... zilch.... damping left in the $20 shock that I got. Although it is a good indication of what the suspension will be like. I need a fastace AR22 or something similar.. $100 new.. probably should bite the bullet and just get it. Tossing up if it's worth trying another 2nd hand jobbie. could always tell the guy I'll test it and bring it back if it's a dud.. might try that??
The front pit-bike brake is ok. you have to pull on the lever hard to get it to perform, and I think the pads are bedding in still as the braking performance got better as my ride wore on.. Unfortunately, I got slower towards the end of the ride (I rode to the squash courts played an hour and a half then rode home), so I was going too slow to really "test" out the braking performance towards the end.
The freewheel on this bike "ticks" once or twice per revolution as you pedal, and sometimes catches when you stop pedaling. I think I will remove it and throw on a better quality unit. I did squish some grease in there before riding it. Also, I might need to tighten the cranks. Towards the end of the ride they were "creaking" a bit under load. they also flex somewhat.
Anyway it was good to get out and get some km's on it just to iron out some of the bugs. so far so good. I think at 250W there should be enough power for ultra long distance leisurely rides along the beach, at >3000W should easily blend with traffic as required on the trip to work.
Anyways no point in pics, it looks the same as before, with the CAV3 fitted, throttle where it should be and the controller mounted in the top section in the frame.
ToDo:
buy a puller, take off rear wheel
pull the side off the HUB, and fit a NTC thermistor - wire to CAV3.
Upgrade phase wires as big as possible
Remove / Replace Freewheel
Tighten Cranks / bottom bracket / Schlumph
Buy rear brake (group buy Tektro Dorado)
Install batteries (due 6th December, but these things often take longer)
Andy
