This LM335 was pre-wired and heatshrunk with only two pins, so the V(adj) pin is probably not used. it doesn't need a +5 supply like the LM35, it is a zener style, and relies on the pull up inside the CA.. Anyway. Motor side covers are back on, and I'll give it a test run to see how it performs, if it's noisy or causes feedback issues I'll open the motor back up and probably re-wire the whole thing. new phases etc.
but I imagine you can't mix and match halls
I actually think you "may" be able to. The halls are physically mounted on the same "phase / coil" but on the other side of the motor, and wired colour for colour, so I think they could be interchangeable. I've not thought long and hard about this but gut feeling is it would work. I could always test....
I am very much waiting for a full powered thrash.. but am holding off wiring the battery in until I get the anti-spark connectors and the 100A breaker. The reason is the battery and controller wires are very short and the more I add / remove connectors the shorter they get. and I don't want too many soldered extensions in the system.
On the plus side i got my chargers today
I'll have to change the connectors on the bigg'un Also, powering up and testing only gave 74.5V on the small charger, the big on had 0V.. but I figure it's a "output on detect" type circuit, so until a battery is plugged in, can't tell.
Andy
