drifter
Hi all, I thought I would have a go at building a friction drive after seeing Kepler's fantastic idea on The Inventors.
I decided to try out the cheapskates method, and only use the bare minimum of parts and use readily available bits as much as possible and also could be easily copied by the average handyman.
I have just finished putting it together and have not ridden it yet but the motor engages and disengages from the tire ok and drives the back wheel while I hold the brake on. I don't know if I can ride it without a throttle as I only have a servo tester. Maybe I will give it a try tomorrow.
Yes that is a $2.00 hinge and a piece of 25mm square aluminium , don't know how the motor will go being only mounted on one end but I will report back. This is a very quickly built prototype to test my ideas and I intend to modify or improve on anything that doesn't stand up to the pressure.
Robbo
Robbo
